Sealed or ported??
Username: Rob932
Post Number: 35
I have decided to get an 18" avalanche and run it with my pcx1500 what type of box do you think will work best??
Username: Invain
Michigan United States
Post Number: 1172
Well, I'm not really sure. I think their meant for sealed, and I know James is running his 15" in a 2.5 cf sealed box.
Username: Taylor17
Kopperl, Texas
Post Number: 789
What about slotted?
Username: James1115
Wilton, Ct
Post Number: 1419
Hey Robbie have you ordered it yet?
Username: Rob932
Post Number: 38
yep
Username: James1115
Wilton, Ct
Post Number: 1427
did you talk to Chad? what kind of box did he recomend for you? what kind of car do you have and what amp?
Username: Rob932
Post Number: 40
i talked to chad he didn't really reccomend one box over another but he said prob better sealed and thats what i plan on doing im not sure what size he said between 4.5cu ft and 8. I have a older ppi pcx 1500 an i got an 01 monte carlo ss
Username: James1115
Wilton, Ct
Post Number: 1431
ok so you are going to be putting 500 watts to it. I would go as big as you can. 6cu/ft would be nice if you could do it.
Username: Rob932
Post Number: 41
i dont know much about boxes my friend built my last box for me i know this may sound dumb but exactly how do you find out cu/ft
Username: James1115
Wilton, Ct
Post Number: 1434
but that amp is also underrated so it would be more like 600 or so. I would go as big as you can with that box. it is going to sound amazing I wish I could hear it when you get it.
Username: Rob932
Post Number: 42
ill post to tell you what it sounds like when i get it
Username: Rob932
Post Number: 43
Username: James1115
Wilton, Ct
Post Number: 1436
cool
Username: Miso
Slovakia
Post Number: 32
check Thielle-Small parameters(EBP-Fs/Qes)
