Arc Audio KAR 900.1...........for my Ti sub.
Is the arc audio KAR 900.1 a good and reliable amp to power my eclipse ti sub.
The amp is 900x1 at 1 ohm, so if i decide on this amp i will hav to get the dual 2 ohm sub.
Are these amps over/under-rated.
Will it be a good match for this sub.
Username: Subfanatic
Walton, Ky
Post Number: 569
welll the ti subs are rms at 750 i believe and from expierience i know they can take alot more...these subs are pretty built to last...id say it should run it very nice...just make sure to watch it for alittle make sure everything is ok..with my new amp im running mine with 900 rms as well...well see how it goes
Username: Invain
Michigan United States
Post Number: 1041
I believe Arc Audio makes very nice amps.
