Sony sd changer needs reseting! but how?
hi all, ive had a sony head unit in my car 4 a while now but without the cd changers that comes with it. i finally brought the cd changer from a friend the other day and got all the leads but when i connected it up and press the source button it says
" reset"
and other times it says
"no mag"
does any one know what i should do to correct this problem? the number on the front of the head unit is
xr-ca430x
and the cd changer says
10 cd changer cdx-656
1 bit d/a converter super suspension
any help would be greatly appreciated -
cookie
I have the same problem. Let me know if you get it fixed.
Matt
Tomb
Simply remove the front panel and behind you will find a small reset button. You will need a pen to press it.
Unbelievable, it fixes the problem!
