Kicker IX402 on infinify 6000cs comp set?? will this work???
infinity
i just got an infinity 6000cs comp set and i was planning to just run them off my HU, but i remembered that i have kicker IX402 in my garage. the ix402 can do 40x2 @ 4ohms and 60x2 @2ohms.
i havnt used this amp on mids/highs before, only on 2 10" kicker comps. is this a good amp to use on my new 6.5" component set? or should i just run the component set off my HU?
infinity
can someone please help me?
is this amp just for subs or will it sound good on my 6.5" comps???
helpme
any1 ???
Username: Carguy
Post Number: 1248
You can use that amp to power your Infinity 6000cs speakers. It'll sound 2x better than your HU anyways.
