Like
MTX vs. Kicker
Username: Rds11
Louisville, Kentucky
Post Number: 48
I need an amp to power my JL 12W6v2. Im looking at the Kicker KX400.1 and the MTX Thunder 421D. I kno the JL 500/1 is supposed to be the best for it but they r so expensive and unless u all kno sumwher to find them cheaper I gotta get one of these. Okay the MTX puts out 420 watts @ 2 ohms which is close to optimum, but thats at 14.4 volts, it only puts out 300 watts @ 12.5 volts, not much but a little underpowered there. I dont kno what voltage the Kicker is rated at, thats sorta wat i need help w/ finding out. which would work best? Also, wat r the extension things on the Kicker amps for?
Username: Marley289
Post Number: 11
get the mtx, its loud and it pounds
Username: Taylor17
Kopperl, Texas
Post Number: 88
Mtx
Username: Jonathan_f
GA USA
Post Number: 2975
Kicker 400.1 is the better amp. MTX is great quality as well, the Kicker is just built a little better. Both are underrated and will deliver the power you need for that sub.
Sean cooke monster
Extension things..u mean the bass boost knob? Its a remote so u can increase/decrease the bass boost.
Username: Rds11
Post Number: 50
no the ends of the kicker amps are a darker color. they come off the amplifier. I dunno what they r 4 tho.
Facebook
Shop Related Deals
Directory
