Glasswolf, help please...
Username: Ivan_k
Hi, on november 14, I posted a thread asking if the Infinity Kappa Perfect 6.1 would fit in the front doors of a 2004 Honda Accord Sedan, and you replied telling me that the speakers would fit if the plastic dish behind the factory speaker was removed. But yesterday, when the guy of the audio store tried to install them, he couldn't make them fit even taking the plastics off the door because of the depth of the speakers...
Is there something else that needs to be done to make them fit???
Thank you in advance for your help...
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7266
where did he run into the problem?
depth?
did he try using a spacer ring to push the midrange out a bit to accomodate the driver?
it takes a bit of work but it should fit into the door without too much modification, and still look stock.
Username: Ivan_k
Yes, he tried using a spacer ring just to avoid the glass, but the door panel wouldn't fit without cutting it.
