I have 2 JL10w3v2 2 ohm DVC subs. I also have a Kicker ZR360 2 channel amp. I want to know the best way to wire the subs to the amp. The amp specs are 90x2 @ 4 ohms, 180x2 @ 2ohms, and 200watts bridged.
If the subs are DVC, 2 Ohms per coil, your best solution is to get a monoblock sub amplifier for them, then wire the coils in series, and wire the subs to the amp in parallel for a 2 Ohm load. There is no ideal way to wire two subs of that configuration to a two channel amp.
Rocky
I want to buy the Alpine MRD M500 and does anyone know where I can purchase one that is at a reasonable price from the UK.
