Who makes the worst subwoofers ?
Lt. Rosta Batch
Poweracoustik or Audiobahn. And any op. on what to stay away from.
Username: Deathshadow
Post Number: 364
Sony
JuNGLiST
Anything from a major store (i.e. Best Buy).
Username: Erik123456
Arlington, Tx
Post Number: 231
legacy and sony
Username: Johnnylemoine
LaPlace, Louisiana United States
Post Number: 326
Kole audio and power acoustik. they are the same people, and they both suck. Also dual. And that sh!t called BAJA from curcuit city when you purchase merchandise for 149 and above.
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 96
Koiler
Blaupunkt
pyle jensen
Hollywood excursions
Klipsch
thump
powerbass
Username: Suicideshifter
Bristolville, Ohio United States
Post Number: 77
http://p079.ezboard.com/fcaraudiotalkfrm27.showMessage?topicID=48.topic
try this site
Username: Jmloughrey
Farmington, CT
Post Number: 580
i've got a pair of blaupunkt 6x9s in my room for my ps2, they sound nice for that, as in a car though and subs, i'd stay away from em...i just needed something cheap, dont regret getting them though, even though they'll never see the interior of my car...
Username: Trev87
Glennville, Georgia Usa
Post Number: 27
hey how do u run speakers like that to your ps2? cause i use my ps2 as my home cd player.
Farmington, CT
Post Number: 585
What i have done is i have my ps2 connected to my VCR, and then i have the audio out on my vcr going to a home audio receiver that powers the 6x9s, i had the receiver lying around in my basement from when my aunt moved in it hadn't been used in years so i adopted it as my own.
For my computer i have my sound card running to a Receivers Aux In lot where the reeciver powers 2 8" Roadmaster subs in custom box with 2 6.5" pioneer spekears and JVC tweeters, not to mention the JVC rear left/right and center speakers.
Username: Subfanatic
Post Number: 17
damien and erik...id like to correct you...id also like to know what you have...because the new 12 inch sony explodes...hit really really hard...they make sh*tty amps...not subs..they are pretty kick a$$...trust me...they hit harder than comp vr's
Username: Zacdavis~
Post Number: 366
powerbass cheap?, ya right!
but yeah i think Thump are on the bottom, but this thread is pointless.
Username: Jonathan_f
GA USA
Post Number: 2830
I was wondering the same thing about his view towards Klipsch. They're not my favorites, but they're definately now low end.
GA USA
Post Number: 2831
*not low end.
Miami, FLORIDA USA
Post Number: 105
evrybody has different opinions on subs. So basically what one person thinks is trash so one else will like. LIke Audiobahn. Some people hate them so much. And some people think that they rock
Username: Zacdavis~
Post Number: 368
good point
Username: Trev87
Post Number: 29
ok jeff but what kind of wire or hook up do you have going from the vcr to the home audio reciever and can i use a regular shelf system to do this?
Farmington, CT
Post Number: 589
simple RCA cable, one goes to my vcr audio out, other to my Receiver Input...
Farmington, CT
Post Number: 590
Sorry, thought i'd draw you a better picture,
i have to AV cable from the ps2 going into my VCR's Audio/video in RCA connections, i then have a 2nd RCA cable going from my VCR audio out to my Receiver audio in.
On my receiver its set to cd because it was meant for a cd player to be attached, on yours it may be Aux in, or something similar
I turn that receiver on when i'm playing my PS2 and the sound is sent from my ps2 through my vcr to the stereo receiver instead of going from PS2 to VCR to TV (or just TV depending on setup)
that should be a little more clear for ya
Username: Bassfreak596
Post Number: 54
blaupunkt my friend has a section under the name 'velocity' which make close to awesome subs. they are competition subs. i dont think they are big in the usa cause they are german by origin. my friend has the 750wrms sub 12" running off a 944w 1ohm stable amp, and the outcome is mind blowing!
definitely not on the crappy list !
GA USA
Post Number: 2835
Usually when we talk about bad subs in general, we're referring to a build quality standpoint. Which subs will fall apart not long after you take them out of the box. Sound quality is such a subjective issue that you really can't force an opinion on somebody, but you can tell them what build and material quality is.
Post Number: 56
i dont have a stand on that because i dont know about its build quality.
i can only say that its been two and a half years that he is using that setup.
