Username: Datboyp Odessa,
TX
Post Number: 10 Registered: Oct-04
Tuesday, November 30, 2004 - 02:52 GMT I've got a JBL BP600.1 amp, and am going to buy two Alpine Type-R 10" subs. What would be better, the 4ohm or 2ohm subs?
Username: Avalanche Post Number: 50 Registered: Nov-04
Tuesday, November 30, 2004 - 03:08 GMT If you don't mind me answering this question I will. Output 4 Ohms: 300W x 1 Output 2 Ohms: 600W x 1 Signal-to-Noise Ratio: >100 Frequency Response (±3dB): 20Hz - 500Hz Total Harmonic Distortion: 0.1% Input Sensitivity: 250mV - 4V here are the specs of your amp. I would buy 2 4ohm subs and run them parallel to get a 2 ohm load on the amp and get the most power out of the amp.
Tuesday, November 30, 2004 - 03:13 GMT Dual 2 ohm version in series/parallel. gives a 2 ohm load, and approx 300wRMS per sub
Tuesday, November 30, 2004 - 03:15 GMT they dont make type-rs in SVC Land... but you had the right idea
Username: Wojopro Post Number: 16 Registered: Nov-04
Tuesday, November 30, 2004 - 06:08 GMT Buy the 4 ohm version like Land says.
Tuesday, November 30, 2004 - 06:52 GMT If you get the dual 4 ohm version you can only run at either 1 or 4 ohms. I see no point in that. care to explain yourself?
Username: Avalanche Post Number: 53 Registered: Nov-04
Tuesday, November 30, 2004 - 10:07 GMT Im sorry I did not reallize that they were dual voice coils My Bad. What I meant to say is that if they were SVC to purchase 2 subs at 4 ohms and Parallel them to make a 2 ohm load on the amp Bridged to be exact.
Username: Carguy Post Number: 528 Registered: Nov-04
Tuesday, November 30, 2004 - 15:35 GMT I'd get 1ohm stable amp instead. You'll get many more choices with it.
Username: Carguy Post Number: 529 Registered: Nov-04
Tuesday, November 30, 2004 - 15:36 GMT I know it's off topic, but it was for future amp buyers
Username: Southernrebel Monroe,
Louisiana
Post Number: 280 Registered: Mar-04
Tuesday, November 30, 2004 - 17:08 GMT the bp600.1 is 1ohm stable. it puts out ~600wrms at both 2 and 1ohm
