138.8 Db's
Username: Skrilluh
Post Number: 30
I just got my system metered ( 2 audiobahn flame compression 12's , 1 hifonics wired at 2ohm for 1000 watt) I hit 138.8 in the floorboard , and 150.2 in the port. In about a month I'll be adding another hifonics amp , running both at 1 ohm for 3000 together. My subs are tuned at 35 hz. I dont know if this is good , decent or bad , so please let me know , Thanks Guys!
Username: Skrilluh
Post Number: 31
The 150.2 in the port was with 500 watts at 35hz (the subs are seperated).
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5988
138.8 isn't bad.
if you want more SPL and aren't worried about SQ, switch to a bandpass box and tune it to the resonant frequency of the car's cabin.. probably around 70Hz.
It'll sound lousy but it'll be louder.
Username: Avalanche
Post Number: 41
that is a good trick Glass.
And your right it will sound lousy.
Username: Zacdavis~
Post Number: 254
good job skrilla, keep those #'s up.
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 274
those #'s arent bad. your just as loud as i am.
was that 138.8dB metered sealed or outlaw?
how big is your box and what vehicle is that in?
Username: Skrilluh
Post Number: 32
Its 3.5 cf per chamber , in a 1989 Ford full size Bronco . The ports are tuned to 35hz. I hit 137.6 in the floor , 138.8 on the windshield , 150.2 in port.
Post Number: 275
what frequency did you peak at?
Username: Joe718
Brooklyn, NY
Post Number: 261
138 is good. keep it up the work.
Username: Skrilluh
Post Number: 34
I peaked at 37hz with their cd , I peaked at 35hz with my cd. I think my cd peaked different because it was burnt and when you burn cds it has to compress it.
