Like
How do i hook up two amps
Username: Legacy
i got two 12 legacy subs each can hold 2000 watts of power. right now they are powered by a 1800 watt legacy amp i got another amp same kind. i want one amp to power one sub and the other amp to power the other sub. how can i do this and what do i need to hook it up both amps are 2 channel
Username: Noblemobile
Van Nuys, CA USA
Post Number: 32
Run a 4 gage power wire into a fuse block splitter depending on what the amp could handle you can run 4 gage out to the amps also but 8 gage would work. Then just bridge the the amp to each one of the subs. Make sure you change the ground to an 4 gage also.
Facebook
Shop Related Deals
Directory
