actually even worse than boss. at least a few people seem to be happy with the boss PD series amps, so I can't totally knock those I guess.
Timtwo32
im looking at a power acoustic amp 1800 watts to push a power amper xp subwoofer 1000watts rms is it possible to push the sub to its max rms with this particular amp?
Hey man did you happen to read the above? DO NOT buy a Power Acoustik amp, it's a waste of your money. Power Acoustik products suck, they burn up, built like crap, break, and at the least are a fire hazard and huge power hogs.
Timtwo32
okay well im fixing to buy a JBL 1200 watt amp to push the same speaker (power amper xp 1000 rms) i believe that this is sufficient amount of raw power to push to amp to its fullest. Does anyone agree/disagree, am i totally wrong?
