Like
Ground Question (multpile amps)
Username: Sr5p33d
Pearl City, HI USA
i have currently have 3 amps that power my sounds. i was wondering if it would make a difference if i had them all grounded seperately or if i ran the grounds to a distribution block and from there straight to the chassis. i know i should keep the grounds as short as possible but it wont be adding much cable if i use the dist. block. all the amps are fairly close to each other.
Username: Deathshadow
Post Number: 80
Sand away sections on the unibody and bolt the grounds down. Sometimes having the grounds together can create noise and its just not a good practice.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 4975
you can go through a block if ya want. sometimes it's easier on a unibody car if ya can't find multiple good ground points.
Facebook
Shop Related Deals
Directory
