Cd player and my amp
I bought a new cd player and i hooked my amp up and we set everything up on the amp where it hits the hardest when i turned my car on the cd player just quit and it won't even turn back on and now my car dings when the keys are out of the ignition and doors closed
Username: Zacdavis~
Post Number: 203
sounds like you've got wires in the back of the deck that are touching eachother
did you check your fuses also?
dont replace any fuses if they are blown without figuring out why they blew, (something may be shorted)
