How to convert Mini DV to VHS tape?
newbie2004
I have a panasonic PV-DV103 mini DV camcorder and I need to transfer the video from that to regular VHS tape. I noticed there is a cable(one round end for mini DV and 3 plugs for VCR/TV) coming with the camcorder which supposed to connect the camcorder with TV/VCR. But when I hook them together, I can't either view it on TV, or record it using VCR.
FYI -- I didn't set any mode when I use mini DV to shoot video.
So how can I transfer it from mini DV to VHS tape?
Thanks a lot,
newbie
Stick the 3 plugs connectors ( red, white and yellow)into the vcr.
Switch the camcorder on to play mode.
On VCR remote , press AV button ( you may have to do this a few times).
Stick in vcr and press record and that should work.
Any probs email me sandmania@yahoo.com
I have a mini DV tape that I recorded in Paris, France.. Using a friends camcorder ( who is in france ) . I would like to watch the tape, but how do I put it on DVD or VHS ? Is there a bigger VHS tape I can put this small one into ?
Please help
Julie
Please e-mail me with suggestions. tp_slc_jnichols@msn.com
LiQUiD
if you have a miniDV camcorder place it in there and watch it or transfer it to your computer and make it a dvd...
good tip sandmania, thanks,
LiQUiD
tonksie
I actually have the same problem. Whenever I play the mini DV on the TV in the "TV/VHS channels" and hit record, it only records whatever TV channel I was on before and not the actually tape. And I can't find the AV button on my VCR remote.
Hi, I did a Mini dv recording with someone eleses recorder and i need to covert it to a vhs tape any soulotions??
