Camcorders And PC's
Username: Charliejz
im thinking of buying a new camcorder but i want one that i can edit using my PC
what camera and what software do you recommend?
Username: Project6
Post Number: 2509
What are the capabilities of your PC?
I don't care what they say about the minimum requirements on the software, you need at least 1G of RAM.
You also need a firewire input on your computer.
Forget USB 2.0
For the camcorder, you need a DV output.
You also need a DV to IEEE1394 cable to attach the DV output of the camera to the firewire input of the computer.
For software, there's Ulead or Adobe Premier(the best), Roxio...you pick.
Username: Fishcca
Post Number: 38
my new XP PC has a P4 with 512 RAM... Berny, This will not do?
Username: Project6
Post Number: 2538
It will work, it will just be very slow. That is why I recommend at least 1 gig RAM.
Username: Fishcca
Post Number: 39
good. Then I will start burning and be patient... Thanks again for the 10th time..
