New member Username: Ricknks2000Post Number: 1 Registered: Sep-06 | Hi, I have a Curtis DVD that plays cdr's and I would like to use my computers speakers. Is this possible. the computers speakers only have one wire that i plug into the computer and not sure where it would go on the dvd. The dvd has a l and r outlet, digital coaxial, s-video and y pr-pb out. thanks for any info. |
New member Username: IncstlouisPost Number: 1 Registered: Sep-06 | Rick - Yes, you should be able to use those speakers. The audio output of the DVD is RCA red/white. The cable end of your computer speakers is 3.5mm stereo. You'll need an adapter that is 3.5mm Female Stereo to RCA Red/White Male Check out p/n 936 at www.showmecables.com Here is a direct link: http://www.showmecables.com/viewItem.asp?idProduct=59 This should do the trick. |
