Fiberglassing a mdf box help
dirrrty2000
I just finished building my speaker boxes to go in the trunk of my 91 Lexus LS400. It is 2 boxes that each have 2 10's. They are going to be pointed at each other about 30 inches apart and I hope they don't cancel out... Anyways, I want to coat the whole box in resin and sand them down so I can paint them. My question is do I need to sand the wood before I coat it and is there a certain resin I need to get?
Thanks
Johnathan
yes sand the wood and use Dryres, can be found at car centers
Username: Jeremyc
Kunsan AfbSouth Korea
Post Number: 69
FYI They make a yellow bondo that is alot easer to sand than the red. You can get it almost any home interior paint store.
Username: Jmloughrey
Farmington, CT
Post Number: 324
why not just paint the MDF?
Username: Insearchofbass
Post Number: 499
he prob wants a certain shape and texture jeff
Farmington, CT
Post Number: 326
true, i was thinking of just fiberlgassing my MDF box for X.X.X and painting it black just so it looks better then flat MDF colorder Painting
Username: Jeremyc
Post Number: 83
You don't need to fiberglass it to get it to look good. Just put a coat or two of an oil based primor and then two coats of paint. (same system used to paint trim in houses)
