Recommended system upgrade
Username: Buffemup
I have a 2003 Honda CRV with one JLW3v2 12inch sub in a sealed box. Its powered by a 300 watt Rockford punch amp. I only have a stock deck system .. i havent upgraded my deck. The sub sounds decent inside the car but it cant be heard very well outside. What is the best way i can upgrade it to make it sounder better outside the car? Some options i can think of is getting a deck, ported box, another sub with more power. (keep in mind i dont want to spend too much money on this upgrade)
Username: Ctx
Post Number: 34
ported box will help alot maybe power wire,ect
Username: Pat_l
Tucson, AZ USA
Post Number: 491
I have your same car, heres what i did!
Username: Pat_l
Tucson, AZ USA
Post Number: 492
Sorry, the picture wont upload. Does anybody know how to upload a picture?
Username: Buffemup
click on "upload image or attachment"
Username: Johnnylemoine
LaPlace, Louisiana United States
y r u concerned how it sounds outside your car if it sounds good inside it dont matter. also a rectangle port for that sub would be awsome
