2002 Camaro
Levin06
I drive a 2002 Camaro with the Monsoon system. The system came with 2 stock 6" subwoofers and (I think) a 500w amp. The passenger side sub does not work anymore and i want to know if some JL Audio 6w0 6" subs would sound any better than some replacement stock subs while still using the stock amp. If a new type of sub would be better, what are some options aside from the 6w0 that i should look at?
Username: Ctx
Post Number: 35
well since a subs only good as the amp thats pushing it I would suggest getting a new amp with the subs,but if thats not in the cards I think the jl's would make little differnce with the stock amp
