Got a question about 8ohm subs
With 600w bridged 4ohm power i've gathered that some of my options per this link "http://www.crutchfieldadvisor.com/S-Szr6cWT7FJK/learningcenter/car/subwoofers_wi ring.html?subs=1&impedance=DVC2x2" are to go with
(1)DVC 12 or (2) 8ohm SVC 12s.
The DVC 12 is easy to find, almost every brand has one. Can anyone suggest an 8ohm 12? I haven't had much luck finding only one. Looking for like $250 for the pair, does anything like that exist?
Also, can anyone suggest a couple of websites other than ebay that has good prices on subs.
Username: Davids2004
Houston, TX USA
Post Number: 503
You could also on that amp run it at stereo mode at 2 ohms and probly get 300X2 at 2 ohms. You will need a svc 4 ohm sub (2)
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=295-555
put two of those in a sealed box.
Houston, TX USA
Post Number: 504
You could also look at two of these.
http://www.ddaudio.com/dd/caraudio/woofers.asp?series=1000
They run about 120.00 a piece but are suppose to be one bad mama.
