Alpine CDA-89812RR
Luc
Hi, im thinking of buying this head unit. Any advice, and can i use an AUX in on that?
Username: Luc
Anyone?
Username: Luc
typo...its cda9812rr
expert
no. You have to use an external bimoldling extension then wrap it around your engine and connect it to a surface area expander from the battery. remember to put plenty of hay in the glove compartment or it will explode.
Username: Luc
very funny
