Is this amp compatible with these subs?
Username: Symplestiles
Stockton, CA
im currently looking to buy 2 12's for my 94 silverado. i have decided on purchasing 2 of the Audiobahn AW1205Q 12" Ultra Excursion Subwoofer ( http://www.etronics.com/product.asp?stk_code=audaw1205q&rpc=367&catid=369&store= ) the amp i am considering is the PowerAcoustik A2400DB 2400 Watts Class D Series Amplifier ( http://www.etronics.com/product.asp?stk_code=powa2400db&rpc=302&catid=305&store= ) here are the specs on each.
Sub:
Massive 180 oz. Double Stacked Strontium Magnets
Power Handling: 1000 watts RMS
Frequency Response: 23Hz - 700Hz
Efficiency: 92.9 dB
Bolt-Tight Motor Structure
PHAT 2" Foam Surround
Laminated Glass Fiber Composite/Pulp Cone
3" 4-Layer ASV Voice Coil
Dual 2 Ohm
1 Ohm or 4 Ohm Operation
Mounting Dimensions:
Depth: 6 3/8"; Hole: 11 1/8"; Diameter: 12 3/4"
Multi-connect Lug Lock Terminals
Amp:
Hi Speed Digital Circuitry
Fully Regulated PWM Power Supply
Four Way Protection
1 Ohm Stable Stereo
Bridging Synchronization
Remote Dash Mount Low Level Gain Control With Cable
System Distress Indicator
Dual Mono Speaker Output Connectors
Gold Plated Heavy Duty Power & Speaker Terminals
900W @ 4Ohms
1400W @ 2Ohms
1800W RMS/2400W Max
Frequency Response: 15Hz to 150Hz
S/N Ratio: 100 dB
THD: 0.5%
Variable Low Pass 50Hz-150Hz
Variable Subsonic Filter 15Hz-40Hz
Variable Subwoofer EQ @ 45Hz
Phase Switch: 0-180
Inputs Sensitivity: 200mV-8V
Dimensions (L x W x H): 15" x 11" x 2.3"
if i run the subs at 4 ohms, then this amp should pump 900watts to each sub correct? please let me know if these 2 products will work fine together. thanks for all you help!
WHOO IM FIRST TO TELL YOU AUDIOBAHN IS ALMOST THE WORSE YOU COULD POSSIBALY THINK OF FOR SPL/SQ
