Wiring..need help quick
Username: Fordtaurusbass
Iowa United States
Post Number: 9
Is there any way to wire two svc 2 ohm apiece subs together to get a 4 ohm load? I have a 4 channel amp and it will only work at 4 ohms. Thanks for any help.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 4310
you won't be able to bridge the amp and run those two subs.
you can only wire one sub to each of two of the four channels.
what you need is a bridged two channel amp for those two subs together.
