I was looking around for some subs and was wondering about the Kicker comp VR's 10". Now i havent heard them before but i was just wondering if they are any good. They are gonna go in a truck just to let you know
Yea the CompVr line of subs from Kicker is really nice. If you give them the proper power they will sound good.
jimmy c
can anyone tell me how i should wire one of these? i just got a c10 and when i hook it up(2 channel jensen 300 watt amp bridged by using L+R- to sub's + & - ) and for some reason it is either really low volume or when turned up just "pops" rapidly... kinda looks like its pushing in, instead of out also
im new to this, so sorry if this is really idiotic
b/c you have a jenson amp buddy. if it has dual voice coils hook them together and then go buy an amp. jk I don't really know a bunch about those particular subs but you probably should invest in a new amp
jimmy c
yeah i know jensen sucks but i've used the same model for years to power various subs and it always works surprisingly well
