Amp sub set up
Username: Jmills74
Running a 900 watt Boston accoustics gt28 with 2 10†jl audio w6 subs @ 4ohm.I’m gonna wire the subs to 2ohm with jumpers in the box.it’s a 2 channel amp.it will do 1350x1 @2ohms.can I wire both subs to 1 channel?sorry I’m a newbieðrunning 4 gauge wire should I upgrade to 0 gauge? If the subs are @ 2ohm when wired to the amp does it need to be bridged or run wires normally?plan on installing 10 farad cap.upgrading halogen to led lights so there’s no dimming.any input would be great thanks.
Need to Register?
Forgot Password?
Enable HTML code in message
