Becker radio
Username: Luffykun
Lisboa, Lisboa Portugal
Hi,
Maybe you can help me. I changed my battery and I don't have my code
Here is the serial number
Audio 10
BE: 3100
SN: 12909859
Thank you
Username: Iwos
Wales
Post Number: 4716
Luffy
Username: Luffykun
Lisboa, Lisboa
Portugal
Hello,
Donations are accepted here Paypal : . . https://paypal.me/CRTM1?locale.x=fr_FR
Code is . . 31243
Contact address : c.r.t.m.auto@gmail.com
Username: Luffykun
I had tried this code but it didn't work.
Username: Iwos
Wales
Post Number: 4717
Luffy
Username: Luffykun
Mail the correct serial number
Or the photos of the labels
Username: Luffykun
Here you go. Upload
Username: Iwos
Wales
Post Number: 4718
The code I gave you is the correct code
Username: Iwos
Wales
Post Number: 4719
Your radio => http://codedradio.info/pics/MERCEDES/be3100.jpg
Username: Iwos
Wales
Post Number: 4720
Mercedes Benz Audio 10
Becker BE 3100
Mercedes Benz
Please note that code entry is only possible when "CODE" is shown in the display. If the display continually shows "WAIT" then the unit may be codelocked and will need to be left switched on up for up to two hours to reset before another code entry attempt is possible.
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE " With " C " Flashing
Enter CODE in the order it is read:
For Example, to Enter Code 12345
Press Preset 1 then 2 then 3 then 4 then 5
If the correct code number is now shown
Press " RDS " To Enter
Username: Luffykun
That is exactly what I did. I got this code before online and I have checked online for my radio and I found out how to do it. I'll try to do it again. Thanks for your effort
Username: Luffykun
Obrigado Joao. Funcionou. Afinal o c�digo que eu tinha parecia com o que me tinhas dado. J� contribui pelo teu esfor�o. Lamento n�o ter contrinuido mais.
Username: Iwos
Wales
Post Number: 4721
Luffy
Username: Luffykun
Obrigado Luis, é uma pena que eu nem paguei pelo café e a cerveja ainda está muito longe.
mas é o gesto que conta
obrigado
