New member Username: Zippy1964Post Number: 1 Registered: Apr-15 | Hi all I need a radio code for my nissan micra, its a blaupunkt with code BP7383A9403149 THANKS |
New member Username: Zippy1964Post Number: 2 Registered: Apr-15 | sorry code could be BP7647383318 thanks |
Gold Member Username: Titanum123Post Number: 1144 Registered: Oct-13 | zippy New member Username: Zippy1964 Post the 14 character Serial Number beginning BPxxxxxxxxxxx found stamped in the metal casing |
New member Username: Zippy1964Post Number: 3 Registered: Apr-15 | Hi qwerty the only 14 digit number on the case is BP7383A9403149 thanks |
Gold Member Username: IwosPost Number: 1054 Registered: Jul-14 | zippy New member Username: Zippy1964 Hello, TRY CODE .. 7606 |
New member Username: Zippy1964Post Number: 4 Registered: Apr-15 | that worked a treat thank you very much! |
New member Username: JimmymarchoPost Number: 1 Registered: Apr-15 | Hi, I have a nissan micra k12 model. Where is the 14 digit serial code? I cannot find it. Thanks |
Gold Member Username: Titanum123Post Number: 1148 Registered: Oct-13 | Jimmymarcho New member Username: Jimmymarcho Remove the radio from the car and after all the letters and numbers on any of the labels, bar codes, and stamped metal body |
New member Username: Johnny72Post Number: 1 Registered: Apr-15 | Hi! I have the same problem like zippy 1964 I have a nissan micra and the radionumber is BP 334947261291 Could you pls help me too??? THANKS |
Gold Member Username: IwosPost Number: 1063 Registered: Jul-14 | Johnny New member Username: Johnny72 Hello, TRY CODE .. 8077 |
New member Username: Johnny72Post Number: 2 Registered: Apr-15 | ALMEIDA Many thanks from a happy Swede It works Have a nice day and thanks again |
New member Username: YuliaPost Number: 1 Registered: Apr-15 | I'm hoping that you may be able to help me by providing me with the security code for a Blaupunkt radio/CD player. It's a unit in my Nissan Micra k12( 2007) Model Nissan Micra MMR CD-G Serial Number BP 5389 7 1326565 Part Number: 7 645 389 318 |
Silver Member Username: Decode_radioPost Number: 705 Registered: Jan-14 | Yulia New member Username: Yulia CODE 8650 contakt me http://forum.kody-radio.pl |
