Nouveau membre Nom d'utilisateur: Sayan1967 Notodden
Please note that code entry is only possible when "CODE ----" is shown in the display. If the unit is codelocked it will need to be left switched on up for up to two hours to reset before another code entry attempt is possible. Code Entry as Follows:
Switch Radio On - Display Shows " CODE - - - - " Press preset " 1 " repeatedly for 1st Digit Press preset " 2 " repeatedly for 2nd Digit Press preset " 3 " repeatedly for 3rd Digit Press preset " 4 " repeatedly for 4th Digit If the correct code number is now shown Press RH Tuning Button " > " To Enter
