Harman Kardon/Becker BE 4773 - need a radio code
Username: Dbkammer
CA - California United States
Hi - I have a Harman Kardon Traffic Pro in my used Porsche. The battery was replaced and the unit now requires a 5-digit code to activate. The Porsche dealer said they can't help as it must have been an aftermarket installation. The model is a BE 4773, S/N 25005762. I've attached a photo of the unit's model and SN sticker.
Can anyone help? I'm going nuts trying to get it working. Thanks!}Upload
Username: Decode_radio
Post Number: 499
CODE 44323
contakt me http://forum.kody-radio.pl
Username: Dbkammer
Hello Decode_radio,
I tried the code above - 44323 - but had no luck.
Do you have any other suggestions, or can anyone else help?
Thank you - I appreciate your effort.
Username: Iwos
Post Number: 633
David
Username: Dbkammer
Hi,
Try Code .. 22123
Username: Dbkammer
Hi ALMAIDA - I'm sorry for the long delay to thank you, I've been traveling. That code worked great - it's permanently recorded in my files. THANK YOU very much!
