Unlock code.
Username: Molski101
Can someone help me with my radio code? Its a blaupunkt,not sure of the model. Serial is BP814618774426, part no,7648146392. Many thanks, much appreciated.
Username: Iwos
Post Number: 455
Molly
try code .. 1244
Username: Molski101
Thanks. It just says radio locked on the display though, how do I actually put the code in? Ta.
Username: Iwos
Post Number: 462
Molly
Please note that code entry is only possible when "CODE" is shown in the seperate display. If the unit is codelocked it will need to be left switched on up for up to two hours to reset before another code entry attempt is possible.
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE " then " - - - - "
Enter CODE in the order it is read:
For Example, To Enter Code 1234
Press Preset 1 then 2 then 3 then 4
The Code will Enter Itself Automatically
Username: Molski101
Thanks, I'm just trying it now, I'll let you know how it goes. Much appreciated.
Username: Molski101
Bingo, it worked! Many thanks again.
Username: Julferen
Hi, Can someone help me with my radio code? Its a blaupunkt (Peugeot 206 N2), model T1 Niv2. Serial is BP8146X3332255, part no,9637082580. Many thanks, much appreciated.
Username: Titanum123
Post Number: 813
julferen
Username: Julferen
try code 2162
Username: Milan1303
Hi, Can someone help me with my radio code for renault senic 2002,no. RN258F20030393 , 8200152345TV750 ,thanks wery much.
Username: Iwos
Post Number: 477
milan
Hi,
TRY CODE .. 4296
Username: Milan1303
Thanks wery much iwos!
Username: Julferen
Hi,
Thanks very much, it worked.
Username: Rike
I NEED HELP WITH A SECURITY CODE
VW PASSAT 2006
TRAFFIC PRO
MODEL: BE 4720
SN: X5014506
THANK YOU
Username: Iwos
Post Number: 484
RIKE
try code .. 35236
Username: Rike
THANK YOU ALMAIDA
Username: Alexandrualexy
please help me with a code for opel astra
siemens vdo cdr500
gm vdo 330886636
no 93171871
thank you and i hope to keep the radio
Post Number: 815
Alexandrualexy
Sorry....your code will only be available from the Main Dealer database or the unit will have to be taken into a Radio Decoding Service
It is unlikely to be available for free or cheap from anywhere on the Internet.
Username: Ac1234
Hi can someone help me with a radio code for a Renault Megane 04?
Many thanks
Username: Iwos
Post Number: 486
ac1234
hi,
Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
Username: Shkoba
Hi ,,
I need radio code for
Jeep grand cherokee 1995
SN = * 1J4GZB8S9SY509248 *
Thanks
