CODE FOR FORD RADIO
Username: Mindis27
MODEL SINGLE CD-KW2000
PART NO 8M5T-18C815
SERIAL NO.V283049
THANKS.
Username: Iwos
Post Number: 336
Mindaugas
Username: Mindis27
Ford V Serial codes are not usually available for free from anywhere on the Internet (unless you can blag it for free from Ford) as they are not calculated using software but require access to the Ford factory database( via a Ford Dealer)...which is not commercially available as software.
Otherwise try your Ford Dealer or a Radio Decoding Service
