BMW Radio/Cassette Code Request
Username: Pearls1
Looking for an unlock code on the following head unit. Here's the only markings that I see: BMW CM 5903. A20910405. This is a radio/cassette from early 90's 3 series.
Username: Decode_radio
Post Number: 382
serial numbers from radio please
contakt me http://forum.kody-radio.pl
Username: Pearls1
The only other marking is:
88 88 1 600 267
Would this be the serial number?
Username: Dekster
POLAND
Post Number: 1947
Richard
Remove the radio from the car and after all the letters and numbers on any of the labels, bar codes, and stamped metal body.
contact me: http://koddoradia.pl/
Username: Regrooster
Post Number: 11760
The CM5903 is an older radio using a different security system and so the code is not calculated using the Serial Number.
It will require further technical advice
Try emailing here
restoredclassic@aol.com
and they should be able to help as I know they have provided others with these old BMW radio codes
Mention this Forum
