Peugeot Clarion Radio code
Username: Bob999123
Can anyone help me with a radio code for a Clarion PU-2294A radio set from a peugeot 106?
I have the codes and numbers ready.
Any help would be appreciated.
Thank you
Username: Titanum123
Post Number: 552
BOB
Username: Bob999123
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio.
http://www.forum-auto.com/pole-technique/equipement-automobile/sujet395936-5460. htm#t14836864
