Opel corsa code
Username: Frou_frou
Please help me with the below
RADIO Philips !
prod. number: FD 0998439084173
I also find the following barcodes in the metal casing:
61/01103/21580/A
9022 213 47789
AND
M/ch 084186
Username: Opelop
Post Number: 100
please all numbers from radio
radio code help my e-mail: opelop@onet.pl
Username: Frou_frou
DC 347/78 MODEL
Username: Frou_frou
THIS?
PH 347FW9084173
I CAN NOT FIND SOMETHING ELSE.
Username: Dekster
POLAND
Post Number: 403
sofia
Username: Frou_frou
Your code is : 1153
contact me:
http://koddoradia.pl/
e-mail: stefan15@poczta.onet.pl
I greet.
Username: Frou_frou
Could you please tell me how to enter this code?
I will open the radio and I will enter the code and suddenly will start to play again?
Do you have any instructions?
Username: Frou_frou
Dear Dekster,
I can not use the code because the radio is closed and it writes "WAIT". Maybe there is enter instructions. I have to put some buttoms before i enter the password!
Do you know something from this?
Username: Frou_frou
Dear Dekster,
unfortunately the code is not correct.
Username: Dekster
POLAND
Post Number: 428
sofia
Username: Frou_frou
From radio to the electronics and read the code from the EEPROM radio
Contact me:
I greet.
Username: Dekster
POLAND
Post Number: 429
sofia
Username: Frou_frou
Contact me:
I greet.
Username: Frou_frou
Post Number: 7
I do not understand what did you mean
Username: Regrooster
Post Number: 11515
To reset your display from WAIT then leave the radio SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself.
1153 has been checked and is the correct code for Serial Number quoted PH347FW9084173
If this code does not work then the radio will have to be taken into a Radio Decoding Service where they will connect a laptop to electronically "read" the code inside the radio's memory chip (EEPROM)
