Unlock key bmw x5
Username: Ramona
good evening
I gently need the unlock code for the radio of my bmw x5,I buy it from other person who have loose the key code and now i have a problem with the radio of the car maybe you can help me.
very thanks
Username: Regrooster
Post Number: 10189
The radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
