1993 Cadillac Radio interconnect diagram
Username: Audiobird
I am seeking the radio interconnect diagram between the head unit and amplifier/ tuner unit on a 1993 Cadillac. Need the color/ function of the wires.
Username: Joe1234
Post Number: 1174
Well any Cadillac? Check out this:
1993 Cadillac Deville Sedan Car Radio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4″ x 6″
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6″ x 9″
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Username: Kaerfpl
Spencerport, NY USA
Post Number: 1407
Hey K.L.Bird, from what I can tell with the lack of vehicle information, any standard Cadillac from 1993 did not come with any Factory Amplifier.
However, if your Cadillac comes standard with the Bose system, then there is an Amplifier connected to each speaker. Each Amplifier will be found and located within the speaker pod/enclosure itself.
If the wiring Diagram that Joe Durkham posted above is not for the correct Cadillac that you are working on, check out the web site below for more Diagrams:
www.the12volt.com
Username: Audiobird
Thanks for the response guys. I think I have it figured out. The box that was given me with the head unit by the junk yard dealer was the tuner pre-amp only. I was able to get audio using an external amplifier and will return to the junk yard to collet the individual amplifier
modules.
