Hello, I need the radio code for my Renault Laguna 2001.
The radio looks like this: http://www.instant-radio-code.co.uk/images/car_radios/Renault-radio-cassette.jpg (from google image search)
This is what I can gather from the radio: MODEL No : 22DC279/62Z Prod No : FD0201420167122 T0B260 RN279F10167122 8200002607TB260
I have already tried code 0740 and it either didn't work or I don't know how to input it. I have entered the code using the 1,2,3,4 buttons and then tried confirming it with all the buttons the radio has and I always got a beep.
Remember to press the final button that stores the code ( ¬ or 6 or 5 ) for at least 10 seconds
============================================== PHILIPS RENAULT CODE ENTRY INSTRUCTIONS
FOR CARS WITH A STEERING WHEEL REMOTE CONTROL
(Note :If you don't have the [ ¬ ] button then push the thumbwheel in and some will have an [ A¬ ] button )
Turn on the radio and the display will show 'CODE'
Use the Steering Wheel Remote Controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit Press the [ ¬] button then rotate the thumb wheel for the correct second digit Press the [ ¬] button then rotate the thumb wheel for the correct third digit Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen, press and hold the [ ¬] button for up to 10 seconds to store the code
IF THERE IS NO STEERING WHEEL CONTROL , THEN USE THE PRESET BUTTONS ON THE RADIO
Press the First Preset Button repeatedly for the 1st digit to be displayed Press the Second Preset Button repeatedly for the 2nd digit to be displayed Press the Third Preset Button repeatedly for 3rd digit to be displayed Press the Fourth Preset Button repeatedly for 4th digit to be displayed
Then press and HOLD Preset button 6 for 10 seconds to store your code
(Note :Some radios use Preset Button 5 to store the code ) ============================================================
