Ford Car Stereo Decoding
Username: Mjido5
my post car is locked,what the solution the decoding ford6000 cd?!!!!!!!!!!!!!!!
Username: Regrooster
Post Number: 9111
The radio SERIAL NUMBER is required for a code
Sometimes pressing buttons 6 & 1 together or 6 & 2 will display your Serial Number
Otherwise remove the radio from the dashboard and post the SERIAL NUMBER found on a label on the casing
It usually begins with M++++++ or V++++++
Username: Eamonh
Dublin 22, Ireland
Hi,
I have lost my code for ford 6000cd rds e-o-n.
My serial number: M194570
Part no.: YS4F-18C815-AC
Help would be greatly appreciated!!!
Username: Bogege
BG
Post Number: 335
Eamonh try code 2682
Username: Eamonh
Dublin 22, Ireland
Thanks a million Bogege, you're an absolute legend!!!
Username: Yos
Hi,
Have I lost my code for ford 6000CD RDS E-O-N.
My serial number: M099201
I would appreciate your help. Thanks !!!!!!!!!
Username: Lethorne1
Hi can someone help me? I need the key code to unlock my ford fusion radio. The serial number is m194716. Thanks!
Post Number: 9153
Lethorne
FORD
Duplicate post....Already answered
Please do NOT post the SAME request in more than ONE thread
It is not necessary....and can cause confusion
Post Number: 9154
re: yos
FORD
Try code 8628
Username: Yos
Reg Rooster
if you only have 1 to 6 digits.
as I lay on 8 and 9
Post Number: 9156
Ford Code Entry Instructions
Once the unit has been turned on the display will show ' CODE - - - -'
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ 5 ] key to accept.
The set should now operate.
Username: Lethorne1
Sorry, i gave you the wrong serial number, its M194796.
Post Number: 9162
M194796.= 7973
Username: Izsoclean
Hi, can anyone provide the code for my sisters stereo serial no. M483600?
Post Number: 9193
M483600 = 7375
Username: Mason22
hi
battery went on my ford fiesta so my code is flashing on my radio. the code isnt in the manual and dont have the keys to get the radio out to see the serial number.
i have pressed 1 n 6 ant it then flashes up b3 aug 09 then 01339v18255. is this the serial number?
its a 4500 rds e.o.n.
can someone help?
Post Number: 9201
Check this number again
01339v18255
If it is a V serial number then it is one digit short
Username: Mason22
i just checked it again. that is what flashes up but the 255 is smaller at the top right hand??
Post Number: 9209
The radio is going to have to be removed from the dashboard in order to find the Serial Number found on a label on the casing and beginning with M++++++ or V++++++
see instructions here
http://www.fitaudio.com/index.php?CategoryID=13
Username: Mason22
got the radio out serial number M180489
Post Number: 9240
M180489 = 8281
Username: Richie1133
Hi i recently changed my battery in a ford falcon and my radio locked i have the serial number 7405742 could any one help with the unlock code Thanks.
Post Number: 9245
Richard Monaghan
Richie1133 posted on Wednesday, November 16, 2011 - 07:17 GMT
Sorry....will only be available from the Aussie Ford Dealer or the unit will have to be taken into a Radio Decoding Service to obtain this code
It will not be available for free or cheap from anywhere on the Internet
Username: Calinmarian
hi can u help me with a code, please. it is a 6000cd e-o-n. part no YS4F-18C815-AA. serial no M308035. thank you
Username: Garnetl
Hi,
My serial number: V008917
Post Number: 9251
Garnet
Username: Garnetl
Garnetl posted on Wednesday, November 16, 2011 - 20:55 GMT
Hi,
Ford V Serial codes are not available for free from anywhere on the Internet as access is required to the Ford factory database( via a Ford Dealer)...which is not commercially available as software.
See your PM message for suggestions
Post Number: 9252
calinmarian
Calinmarian posted on Wednesday, November 16, 2011 - 20:02 GMT
sorry, i did not know how things work.i won't make the same mistake again
Username: Kaneshka007
Hi...!!
Please help me cani find here unlock code for my Ford Mondeo 2001CD/Radio 6000. Serial number is: M247168
Thank you
Post Number: 9268
M247168 = 9893
Username: Racma
Hi,
I have lost my code for ford fiesta 4500 rds e-o-n.
My serial number: M688021
Post Number: 9298
M688021 = 5547
Username: Nermin02
hi, i have lost my code for my ford 6000 cd rds eon my serial number is / M094919
Username: Sunnychandi
Hi
I have tried using the code that came from Ford with my manual but it doesn't work.
My serial number is M134897 and the code I have is 1684.
Hope someone wouldn't mind checking the code for me.
Much appreciated.
Username: Jackie111
hi iam looking for a code for my ford radio M530391 pin YSF18C815AA thanks a million
Post Number: 9313
FORD Codes
M530391 = 2726
M134897 = 1752
M094919 = 2816
Username: Jackie111
Thats great Reg Rooster thanks a million
