Please help renault megan code
Username: Moses55
hi please can somebody help retreive my code from renault megan 2005,,disconnected battery to have starter replaced now lost code,would very much appreciate if somebody can help,thanks.Upload
Username: Regrooster
Post Number: 8668
try code 8370
Username: Moses55
thanks reg rooster,problem i got now is that i tried another code earlier which i thought might be right but after input it says "ERROR",,,,my question is do i need to leave it powered on for a while before i can enter correct code? thanks.
Username: Hay88
PortsmouthUk
Post Number: 3769
yes leave it turned on.
note the radio does not lockout after a wrong code entry it only doubles the time to wait before
the next retry...if a wrong code is entered it will display error then after the delay should display "0000")
Username: Moses55
thanks both especially reg rooster all sorted,very much appreciated your both champs.
Username: Dobdoba
Please can somebady help retreive my code from auto-radio renaut scenic 1.9dci 2005 ; n ° JMRG06
thnks
Post Number: 8698
chabli abderrahim
Username: Dobdoba
Dobdoba posted on Friday, September 16, 2011 - 09:40 GMT
thnks
Sorry.......this is insufficient information
The radio has to be removed from the dashboard
Then quote the 14 character SERIAL NUMBER beginning with
RN* * * * * * * * * * * * found stamped in the metal casing.
Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
