Honda civic radio code2008
Username: Hani
hi,
i have changed my battery last week and now radio is asking for unlock code. can any body help me ?
Honda Civic 2008
Radio Serial # U3005L5517
thanks
Username: Regrooster
Post Number: 8699
HONDA RADIOS.................IMPORTANT NOTICE
The code may be written on the radio or on a card in the glovebox (or similar "hidden" place )
Further suggestions may be found here
http://www.youtube.com/watch?v=tgfRmBo7Pu0&feature=related
HONDA do not make radios .They only affix their badge onto radios made by the large manufacturers (ALPINE , BLAUPUNKT etc).
The majority of HONDA codes are NOT readily available as access is required to the original factory database which is not commercially available to buy
HONDA radios are made by the following manufacturers
ALPINE
AUTOSOUND
BLAUPUNKT
CLARION
KENWOOD
MATSUSHITA
PANASONIC
PHILIPS
PIONEER
The only Honda radio codes that are available to be calculated for free from anywhere on the Internet will be radios made by
BLAUPUNKT.
These will have a Serial Number beginning with BP and another number beginning with
7 *** *** *** found on a label on the radio casing
Plus older radios made by
PHILIPS …Model 22 DC681/02
Early ALPINE (Model numbers beginning CM+ + + + )
UNFORTUNATELY ... NO OTHERS !
For EVERY other HONDA radio made by one of the other manufacturers then visit the website below
https://radio-navicode.honda.com
If you can supply all the correct details, then they will be able to supply your code for free.
Otherwise you will have to try your HONDA Main Dealer or a Radio Decoding Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM)
Useful HONDA Contacts
TELEPHONE NUMBERS
Honda UK 0845 200 8000
Honda USA 1-800-999-1009 (Toll Free)
Honda Canada 1-800-387-5399 (Toll Free)
Honda Aus 1800 804 954 (Toll Free)
Honda NZ 0800 2 46632 (Toll Free )
