Need Radio Code for my Wife's Renault Clio
Username: Shafiu
Please can you help me with code for the Radio of a Renault Clio car which my wife bought recently. we could not find the code in the papers. The following number are on the radio set.
Model Number: 22DC278/62B
TOF739
RN278F30373006
PROD No: FD0403050373006
Another Number: 8200057681TF739
Username: Regrooster
Post Number: 8596
try code 3127
Username: Shafiu
Thank You Reg. I want to enter the CODE but the ERROR sign is still on the display. The manual says I have to wait for up to 32 minutes due to previous wrong CODE attempts. I have waited hours but the ERROR sign is still there. How do i get it away?
Thanks in advance.
Shafiu.
Post Number: 8599
Leave it SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself.
The important word is UNDISTURBED because if it is interrupted then the waiting time starts all over again
This can take an hour or longer ...depending on how many wrong codes have been entered previously
Username: Shafiu
Thanks Reg. I am grateful. i will be patient and ask my wife to be patient too.
Shafiu.
Username: Shafiu
Great Reg. It worked after waiting for more than an hour.
