Very big problem radio code
Username: Vlatkomarkov
hello
I have very big problem.
the wrong code on my radio 3 times,now just write code.
I do not give to insert code, if anyone knows help me.
My radio is.
PHILIPS 22DC594/62F
FD 00 9637 3008758
9022 215 94623
BAR CODE 7700 413538 F757
thank you
Username: Regrooster
Post Number: 7992
try code 3189
Unable to insert the code because no 0000
just write code, if there is a reset button
thank you
Username: Hay88
PortsmouthUk
Post Number: 3686
leave it turned on to reset
note the radio does not lockout after a wrong code entry it only doubles the time to wait before
the next retry...if a wrong code is entered it will display error then after the delay should display "0000")
You must hold at the end to store your code.
IF YOU DONT HAVE ¬ KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A¬} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press and HOLD button 6 to store. for 10 seconds
and on some it's hold 5 to store.
