Renault Lagun Lost Radio Code
Username: Renult53
Please help...
Model No. RENRDW103-11
TOR066
RNRD0730002382
Product No. FD0103360002382
Bar Code: 8200317489TR066
397 K74
3940410 1
Radio 7489
CD 1208
KGOGO 629613070 DD
Thanks in anticipation
Username: Hay88
PortsmouthUk
Post Number: 3495
renault53
code 8925
you must hold at the end to store your code.
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE "
Then " 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " A " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " A " Until A Beep Is Heard
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press and HOLD button 6 to store. for 10 seconds
and on some it's hold 5 to store.
Username: Renult53
Thank you very much. Fantastic!
