Radio code needed please!
Username: Djfaze71
Hi i`ve just had to replace the fuse for the cd player in the car & now it`s come up with code in on the lcd panel. I cannot find my code!!!! Can anyone help pleased ? It a factory fit clarion model number - PU 2294A© - serial number - CL0401Y0384318. Other numbers i found are as follows - 286-8497-33.... e13020410....GSM104....0080905D Hope this helps.
Username: Regrooster
Post Number: 7143
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
