Renault Clio 2002 need code for radio please
Username: Cherice
Hi there
Please can someone provide me with the code for my car radio.
The only info I can provide (which I think is the serial number of my car?) is VF1BB130F25819549.
Thank you!
Username: Hay88
PortsmouthUk
Post Number: 3439
you need to remove the radio.
they are too small holes each side of the radio
use an old metal coat hanger 4 darts or very small screwdriver or long nails.
put into holes about 4-5cms and push outwards sideways
and carefully pull radio forward.
you must do the holes on each side at the same time
Then post the numbers/letters from below the main fat barcode
something like 7700xxxxxxtt123 or 8200xxxxtt123 or
the security code like Q123 or T0U123
can be found in a small box then i can help you
off of the radio
Username: Edson_mapenda
Hi,
I need a radio code for my renault laguna (Tunerlist radio, not sure if it is the one that originary came with the car)
model no: 22DC279/62Z
below the first bar code there are these
numbers (NOT SURE IF THEY'RE PART OF THE MODEL NO): T0S018
RN279F10140241
product no: FD0101350140241
security no: 8200002607TS018
?? no: BG0V0525412231
Will be grateful if i can get help on this!!
