2002 Blazer-Locked
Username: Tpilacinski
I have taken the radio from a 2002 Chevy Blazer and installed it in a fish house. The display now reads "LOCKED" even after I have used it several times. How do I unlock the radio?
Username: Regrooster
Post Number: 6062
Remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
The part # is 15091316
The bar code # is 89DPBWM121005064
There are several boxes on a sticker within which are the following:
URT N19 Burn in V8 C.Check L41 EEPROM D 17
Visual N10 Audit L17
It is an AC Delco radio from a 2002 Blazer
Is there a code I can punch in to unlock this radio?
Post Number: 6146
Sorry...DELCO codes are only available from the Main Dealer or a Radio Decoding Service
