Radio Code for a 1998 Renault Laguna
Username: Ginger65
Please help, facing a long journey and only got the car serviced and you've guessed it, they changed the battery.
Make:- Philips
Model:- 22DC459/62E
Serial Number:- RN459FV2008808
Username: Hay88
PortsmouthUk
Post Number: 3313
hi ginger post the numbers/letters from below the main barcode
something like 7700xxxxxxtt123 or 8200xxxxtt123 or
the security code like Q123 or T0U123
can be found in a small box then i can help you
Username: Ginger65
D'oh
Radio sat 6010
7700 426 483 T924
Username: Hay88
PortsmouthUk
Post Number: 3316
Ginger65
code 6016 you must hold at the end to store your code
Code Entry as Follows:
Switch Radio On - Display Shows
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press and HOLD button 6 to store. for 10 seconds
and on some it's hold 5 to store.
Username: Ginger65
Thanks for the very very prompt reply, hopefully the code will work and it will save my sanity on the journey
