Renault Kangoo Radio Code
Username: Crnibranko
Model No: 22DC229/62M
Prod. No: FD0001160002339
Please help.
Username: Hay88
PortsmouthUk
Post Number: 3287
hi post the numbers/letters from below the main fat barcode
something like 7700xxxxxxtt123 or 8200xxxxtt123 or
the security code like Q123 or T0U123
can be found in a small box then i can help you
TOT740
RN229F10002339
8200153737TT740
8200 153 737---
Thats all :D.
Username: Regrooster
Post Number: 6046
try code 6 2 9 5
radio have numbers from 1 to 6. how type 9?
(sry my english isnt good)
Username: Hay88
PortsmouthUk
Post Number: 3288
you must HOLD AT THE END TO STORE THE CODE.
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE " Then " 0000 "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press and hold preset " 6 " To Enter
