Lost radio code
Username: 20moves
Usual story, lost battery in cold weather for my rover 220sd phillips
radio;
Serial no: RG594FT2104662
Model no:22DC594/60E
FD 0396412104662
Security code: TOA 3602
Hope you can help, fed up with no sounds now!!
Username: Hay88
PortsmouthUk
Post Number: 3192
20moves
please check your security code TOA 3602
one digit to long
Username: 20moves
Not sure if I'm looking in the right place! The only TOA number I can find is tiny and appears on the side of the radio but within the casing if that makes sense! I've just checked again and it says TOA3602, is there anywhere else I can look? I can have a better look in daylight tomorow! Really grateful for your time.
Username: Regrooster
Post Number: 5829
Try code 3 6 4 9
Username: 20moves
Thank you so much, FANTASTIC!!! Got my music back!!
Username: Ohxsh
Hi,
Can you help me with a code for my Ford Focus radio FD6000 Serial Number is M064907. I bought the car for my daughter and in some moment the car shop had disconnect the battery. Thanks in advance!
Username: Automods
UK, Kent UK
Hi,
code is : 6444
Username: Ohxsh
Thanks a lot I try this code when I go home after work.
Username: Ohxsh
Thanks again! The cd-player works perfect
